Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Stl translator faliled
7 REPLIES 7
Message 1 of 8
1016 Views, 7 Replies
I'm trying to save this file it was the word mom with the "o" being a gimball. My dad asked if i could make it say oscar for his coworker.
So i imported it, then cut away the "m's" and added the scar to the end. and when i try to save the whole thing it won't let me, so i tried saving it one at a time then assembling it later. but it says these to error messages.
"Error: Autodesk Translation Services failed to translate the current document to stl file!"
And
"Error: STL Translator failed to export data"
any ideasFull thing.Full thing.
Just the Oscar bit.Just the Oscar bit.
Middle ring.Middle ring.
Inside ring.Inside ring.
7 REPLIES 7
Message 2 of 8
ahreum.ryu
Hi @Anonymous,
Thank you for posting!
Could you share your design? Here is how to share it. (ahreum.ryu@autodesk.com) . I tried with a simple model and it seems to work. so I would like to look into your model.
This thread may help.
I look forward to your reply
Many thanks,
Message 3 of 8
Brady_Fulton
in reply to: ahreum.ryu
I'm having similar (maybe the same) issue. If I try to "Make", it fails the first time. I have to run the Make command a second time and then it's able to move the design into my slicer software (Cura 3.1.0). Screenshots attached.
Message 4 of 8
ahreum.ryu
in reply to: Brady_Fulton
Hi @Brady_Fulton
I'm sorry you are experiencing this issue. Could you share your design? Here is how to share it. (ahreum.ryu@autodesk.com)
Many thanks,
Ahreum.
Message 5 of 8
Here's the public link.
Oscar gimble
If you need to copy and past it.
http://a360.co/2nbprAb
Message 6 of 8
This is great when I clicked the link to test it I saw a download button and clicked and it worked.
If you have an idea on how to prevent this I'm all ears.
Message 7 of 8
ahreum.ryu
Hi @Wingedthing0
Thank you for sharing!
In my laptop, it's working, Could you take a look at my steps
I tested it on Mac, Win7, Win10 and it seems to be ok. Could you check Fusion 360 is installed by up to date (2.0.3800)?
Many thanks,
Ahreum.
Message 8 of 8
Brady_Fulton
Restarted computer this morning. Opened up Fusion 360 and was notified that there was an update pending a restart of the software. Did that and haven't seen the issue yet today. Thank you for your response.
