Fusion Support
Spot drill?
4 REPLIES 4
PetePayne
1220 Views, 4 Replies
Spot drill?
For some reason I can not figure out how to spot drill.
I see the spot for peck drill though.
I know it is there , I just cant find it.
Thanks for the help.
4 REPLIES 4
masa.minohara
in reply to: PetePayne
Hi @PetePayne,
Thank you for posting! I think this learning page contains helpful information for you. Please let me know if you have any questions!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
PetePayne
in reply to: masa.minohara
Thank you!
I will sort through it.
PetePayne
OK , that looks good .
But lets say I just want to center drill or spot drill to locate a .250" hole .
Like
Spot drill it .020" to center the larger next operation .250" drill.
If I use a 3/16" center drill it want to go to a Z-.236 depth.
How do I limit the depth to like .020" ?
Thank you for the help!
masa.minohara
Hi @PetePayne,
Than you for your response and I am sorry for my slow response! Could you try changing the Bottom height and setting it to "From Hole top" and using the negative value for the offset? I think this should work to limit the depth. Please let me know if you have any questions.
Masanobu Minohara
