My sketch has small white dots (or circles) at some of the line intersections. I don't want white dots in my drawing - how do I get rid of them? Took me 45 minutes to learn how to get rid of the blessed dimensions I don't want, now I've got dots to delete! Thanks.
Solved by jeff_strater. Go to Solution.
those white dots indicate an unconnected point. You have not connected those lines to the intersecting lines. Use the Coincident constraint to force this connection:
And how do i do this if this is a cirkel with some dots i dont want.
i want hole cirkel to be together so i dont gets line on the sides when i extrude it later on.
