In my small team I can no longer transfer legacy folder into folder-level security folders. The dropdown only shows archive as an option.
Hi @jmyrick529QU ,
Thanks for reaching out. Project transfer has some requirements (like you need to be an admin in the source hub, and at least have member-status in another hub as the destination).
How to transfer files and projects between Hubs in Fusion (autodesk.com)
From your description, it maybe that you are looking to convert a legacy project to a Folder-Level Project? If that is the workflow you are looking for, it was temporarily disabled as an issue was identified that is being corrected before it is re-enabled.
Please let me know if that helps or if I have mis-understood the question.
Thanks!
