Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Small team, folder-level project transfer no longer available
1 REPLY 1
jmyrick529QU
83 Views, 1 Reply
In my small team I can no longer transfer legacy folder into folder-level security folders.  The dropdown only shows archive as an option.
1 REPLY 1
Andy.Spivey
in reply to: jmyrick529QU
Hi @jmyrick529QU ,
Thanks for reaching out.  Project transfer has some requirements (like you need to be an admin in the source hub, and at least have member-status in another hub as the destination).
How to transfer files and projects between Hubs in Fusion (autodesk.com)
From your description, it maybe that you are looking to convert a legacy project to a Folder-Level Project?  If that is the workflow you are looking for, it was temporarily disabled as an issue was identified that is being corrected before it is re-enabled.
Please let me know if that helps or if I have mis-understood the question.
Thanks!
Andy Spivey
SQA Engineer
Technology Administrators
