I am experience slow performance when working on a design that uses several external components. This started happening with the latest update (March v.2.0.18719). The external components are all nested in a single component. The slow performance begins whenever I hide/show that component, also when the component is expanded via the triangle icon. Fusion stalls for about 3-5 seconds, meaning the interface and tools are frozen as if something is being calculated in the background. I'm not sure how or if this can alleviated but I thought I'd share my experience. Thank you
Solved by Adafruit. Go to Solution.
Thanks for sharing the model. I cannot reproduce these performance issues on the two Windows machines I currently use.
