I can't seem to even get started with forming Multiple holes. I can do a single hole ok, but I can' t figure out how to make the "sketch points". All the help links I looked up so far are well past the very beginning where I am. I tried making a body rectangle and tried to put 4 holes around the corners. A screen video would be helpful starting from the very, very beginning.
Hey 2herds,
Sketch points in this tool refers to... well... points in sketches. When you you select Placement > From Sketch, you can select multiple points on any sketch as centers for the holes (which will all have identical properties). Here's a youtube video that explains it: https://youtu.be/tZRL-c131Ok?t=2m31s
Hope this helps!
Hello 2Herds,
You can make multiple holes using sketches. At the minimal level, you can create points and then use them as centre of holes...
In this example I have made a sample cuboid and sketched some points on the top face of the object. These will be the markers for the multiple holes.
You can then use the hole tool. Use the 'From Sketch' option and select all the points. Define your desired hole parameters and you have multiple holes.
You can use other tools on the points to make the task quicker for multiple holes. For example, you can use the rectangular pattern tool to make a grid of points which you can use to make multiple holes.
Same procedure as before.
Alternatively, if you want your holes to follow a rectangular/circular pattern then you could try this second method:
Start off by making at least one hole. Then open the tool you would like to use, for example the rectangular tool, and select the inner cylindrical face of the hole (the inside curve of the hole). Then adjust the parameters to make your grid/pattern.
Whichever method you use, you should end up with multiple holes. Your holes do not need to go through the whole of the object for this to work. There may be more efficient and better ways, but I am new to Fusion 360 and this a quick way/workaround I have found.
I hope this has helped you
Thank you, now got it working. I hate to say it but I was missing the Sketch Point operation. Most instructions I did find left out the "basics". Thanks for putting together a step-by-step procedure for beginners. 😄
I don't get it. I can't make these instructions work.
As soon as I click "Finish Sketch" my sketch disappears and I can never seem to make it reappear
within the Hole Tool dialog in order to select the points in the sketch to create the hools.
Is the Eyeball for that sketch turned off? Toggle visibility with the browser Eyeball icon.
You can edit a hidden sketch, when finishing it, it will still be hidden.
Might help....
does not work in 2.0.9512so much has changed, where is everything. The downside of cloud software they can move the furniture without asking you.
What doesn’t work now?
Sketching, points, holes, visibility, patterns,
even pushing updates works.
One problem with the "from sketch" option is that it will only make a hole in one direction! I tried to make holes using 3 sketch points but it only wants to go one way (away from the body) then complains there is nothing to cut. Doh! Entering a negative distance doesn't work either.
Attach your model and let the Forum users give you some possible help. If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Sure, here it is. I want holes where the three points on the inner circle are, countersunk at the point as per below (achieved by using the "single hole at point" selection.)
You did not say which side of the bracket you wanted the but since you were having difficulty, I assume you want them on the side opposite the bent flange direction. You also did know say what size so I used M4. If you want to use the Hole command to create Countersunk holes, you have to have the sketch points on the side of the material that receives the countersink. In your case, all you have to do is transfer the sketch points to the opposite side of the bracket. Model is attached.
John Hackney
Retired
I though it was pretty obvious from my screenshot that I want the countersink where the point is. The point is on the backside, i.e. the same side as the flange. That's where I want the countersink. Moving the point to the other side does indeed allow the multiple hole feature to work, but it doesn't achieve the desired result. In this particular case I could have reversed the flange, but that's not a general solution. Why can a single hole go either direction, but multiple holes only one?
The "flip direction" control will change the direction:
Thank you - that's what I was looking for.
On checking I see that the single hole option also has that button (after selection of a face) but of course it's rarely needed because the face itself usually defines the correct direction. It would be nicer if the UI was consistent with the extrusion tool (i.e. dragging the arrow would flip the direction, or negative distance could be used) but at least the functionality is there.
