Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sketch problem
3 REPLIES 3
224 Views, 3 Replies
Sketch problem
Hi Fusion Family,
I have recently imported an .step file in fusion 360 (processed from 3D scanner and GOM 3D software) I wanted to reduce the thickness of a pipe like part from inner side. But I couldn't select 3D sketch for that surface. What could be the possible reasons? I will attach the link for .step file here.
https://drive.google.com/file/d/18prS8iA8AtrlsXDwJJXgD5cABQAvljMU/view?usp=drivesdk
3 REPLIES 3
TheCADWhisperer
Can you Attach the file directly here?
jeff_strater
Thanks for access to the file, @Anonymous
I'm not really sure what is meant by "But I couldn't select 3D sketch for that surface", but I understand that you want to reduce the thickness of this pipe.
Because this is imported geometry, things like Press/Pull or Offset Faces do not work.  In the screencast below I show one way to do this with Sweep and a sketch.  I meant to turn on feature history first, and just forgot to do that, but I would recommend that, definitely.
I only did one side of these handlebars, because the grooves in the middle stop the edge I used for the path.  If you want the middle part to be thin as well, you will have to modify the path in that area to allow it to continue.  I only did one side, as well.
Jeff Strater
Engineering Director
in reply to: jeff_strater
Hey Jeff,
Thanks for the help. There was a path going through the inner side of the pipe. Sweeping through that path helped.
Regards
AJAY
