Hi Fusion Family,
I have recently imported an .step file in fusion 360 (processed from 3D scanner and GOM 3D software) I wanted to reduce the thickness of a pipe like part from inner side. But I couldn't select 3D sketch for that surface. What could be the possible reasons? I will attach the link for .step file here.
https://drive.google.com/file/d/18prS8iA8AtrlsXDwJJXgD5cABQAvljMU/view?usp=drivesdk
Solved by jeff_strater. Go to Solution.
Thanks for access to the file, @Anonymous
I'm not really sure what is meant by "But I couldn't select 3D sketch for that surface", but I understand that you want to reduce the thickness of this pipe.
Because this is imported geometry, things like Press/Pull or Offset Faces do not work. In the screencast below I show one way to do this with Sweep and a sketch. I meant to turn on feature history first, and just forgot to do that, but I would recommend that, definitely.
I only did one side of these handlebars, because the grooves in the middle stop the edge I used for the path. If you want the middle part to be thin as well, you will have to modify the path in that area to allow it to continue. I only did one side, as well.
Hey Jeff,
Thanks for the help. There was a path going through the inner side of the pipe. Sweeping through that path helped.
Regards
AJAY
