Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sheet Good with finished faces
6 REPLIES 6
chrisCFHNJ
400 Views, 6 Replies
chrisCFHNJ
How are others handling sheet goods that have a veneer, laminate, or melamine applied to one or more of the faces?
For something like this, I would think we would select MDF as the material. But we need to be sure that these parts are not mixed up with other parts that are raw MDF with no melamine face, especially given that some of the thicknesses may be exactly the same.
Also, with materials with a face on one side only, which side this face is oriented is important.
Is there any way of handling this in Fusion? Any thought of developing something?
6 REPLIES 6
jhackney1972
in reply to: chrisCFHNJ
jhackney1972
Most important is to apply the Material to the component so you can make sure the mass properties are assigned.  Then use the Appearance command to assign the material to Faces to assign specific surface materials.  The appearances do not contribute to the mass properties but normally they are not a substantial contributor to these properties.
John Hackney, Retired
chrisCFHNJ
in reply to: jhackney1972
chrisCFHNJ
Right, I know how to apply appearances to the face, and that does make the parts look correct. However, we are nesting the parts on sheets. I need the system to divide the parts up based on not only the core material but also the face material.
jhackney1972
jhackney1972
In that case you will need to create custom materials and include the surface appearance.  Fusion 360 will not sort components based on appearance only materials.
chrisCFHNJ
chrisCFHNJ
Is there a way to create a material that has a core appearance and face appearance that are different? That would be great, but I don't know how to do it.
jhackney1972
jhackney1972
I have tried but unfortunately I have not found a way yet.  It is an interesting possibility and I will keep looking, but do not hold your breath.
chrisCFHNJ
chrisCFHNJ
ok, thank you for your help.
