Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Shading fillets in a shaft are poligonal
2 REPLIES 2
CAMXPRESS
162 Views, 2 Replies
CAMXPRESS
Hi All,
The shading performance of a shaft with fillets is not smooth, looks like a polygon.
If I export this shaft to STEP and open another CAD system (PowerShape) everything is fine.
So the problem is not with the model, just the shading quality.
(Other models are good, VGA driver is the latest, 3060Ti, W10)
Do we have any control over the shading tolerances to get better visual quality?
Joe
Hi All,
Joe
2 REPLIES 2
HughesTooling
in reply to: CAMXPRESS
HughesTooling
If you right click the body in the browser there's an option "Display Detail Control" Try changing from adaptive to Fixed then high.
Mark Hughes
Owner, Hughes Tooling
Mark Hughes
CAMXPRESS
CAMXPRESS
Hello Mark,
Thank you for the quick and valuable answer! It is working for me.
Joe
Hello Mark,
Joe
