Hi All,
The shading performance of a shaft with fillets is not smooth, looks like a polygon.
If I export this shaft to STEP and open another CAD system (PowerShape) everything is fine.
So the problem is not with the model, just the shading quality.
(Other models are good, VGA driver is the latest, 3060Ti, W10)
Do we have any control over the shading tolerances to get better visual quality?
Joe
Solved by HughesTooling. Go to Solution.
If you right click the body in the browser there's an option "Display Detail Control" Try changing from adaptive to Fixed then high.
Mark Hughes
Owner, Hughes Tooling
