Save as .stl not available anymore
poporacer
poporacer
I used to be able to save an object as an .stl file by right clicking on the object in the tree and it was an option there. Now it is no longer there? I did it earlier today but now it is gone. I shut F360 down and opened it back up and it still isn't there?
I can go through the export process but that takes some time. Did this feature get removed?
Replies (14)
christian.tapkenKLE4M
It is not removed, but renamed as "Save As Mesh". It should have the same functionality, but also can save 3mfs.
poporacer
Thanks! That was it!
NarlyB2
I was also very confused.  Normally I see changes like this covered in the what's new updates.  I did not see a notice that this changed.  The new save as dialog has changed.  You can now save as 3MF format and select the units for export.  I would like to see this covered in a supplemental What's new update.
It dosen't have the "safe functionality" on two counts -- first it NEVER defaults to save as STL [and there's no way I could see to make it do that], and second, it doesn't pre-fill-in the suggested file name with the file you're saving.  Both were very nice conveniences when there was "save as STL" available directxly
john_meyerPN8R4
This is why I cannot stand subscription software. You wake up one morning, wanting to get work done, and suddenly things have changed. I did not want to upgrade at this moment, but was forced to. I just wasted half an hour trying to figure out what had happened. Thank you to the support people for helping out, but no thank you to the marketing people who force us to change when we're being perfectly productive with what we have.
I want control over when the software changes !!!
andywilx1
When saving as Mesh or 3D Print and using the Print Utility to send to Cura, the dialogue box defaults to 3MF and you are unable to change to STL!
Select a different slicer and the Format option is available.
This has only just happened today 28/8/21.
WHY? Is this a Cushion issue or a Cura issue?
3MF means when I send to Cura I get the multiple bodies that make up my model, that can't be scaled or moved in as one without exploding. Also the model is positioned off the print bed!
WHY?
laserempire
Well, this feature seems to not be working at all anymore...
Anyone else have this issue? Did I hit a weird key combination?
I right click on the body, then click "Save as mesh", then nothing happens, no extra menu pops up anymore...
g-andresen
If this menu does not appear, I recommend a CLEAN UNINSTALL
günther
laserempire
Just reinstalled with no luck.
Those menus will no longer generate
scaytrase
Community Visitor
Community Visitor
The problem is that "send to 3d print utility" is broken after every Cura update as the Cura location is changed each time. And when it's selected to "custom" to workaround this - only STL is allowed and not 3mf. When Cura is selected - only 3mf is availabled (select is disabled totally) but it doesn't actualy do anything - not launching Cura (this is the old problem). So the problem is with "send to 3d print utility" checkbox. if it's unticked - I can choose everything, but that's not workflow I'm using
vjtocatjian
Observer
Observer
Hey Ya'll, this post has been super helpful but I'm now finding that when I 'save as mesh' to an .stl, I'm getting errors. How do I get it to work and what am I potentially doing wrong?Screenshot 2024-03-12 at 11.22.29 pm.pngScreenshot 2024-03-12 at 11.25.36 pm.png
CGBenner
@vjtocatjian
Hi, do you still need help with this?  Can you share a file where you see this error?
Chris Benner
Industry Community Manager – Design & Manufacturing
g-andresen
This can happen if you are in offline mode and have already saved the design.
In this case, you can first export the design to a local drive and then open it again in Fusion > right-click > save as mesh
Günther
vjtocatjian
Observer
Observer
Thanks @CGBenner and @g-andresen for your replies.
I am working online, have gone through all the troubleshooting and nothing seems to work.
I finally tried to download from the Fusion teams page and that seems to have worked and the item is printing fine. Major pain, though, that none of the .stl options are working for me in the program.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
