Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Support
Rhino 6 .3dm Files Fails to Import
6 REPLIES 6
ec2638
1992 Views, 6 Replies
Rhino 6 .3dm files fail to import into Fusion.  Rhino 5 imports fine.  Please fix!
Thank you!
FYI - Your import documentation reads:
Rhino Files (*.3dm)
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
6 REPLIES 6
ryan.bales
in reply to: ec2638
You could try uploading via A360 instead of through the data panel.
Ryan Bales
Fusion 360 Product Support
HughesTooling
in reply to: ryan.bales
@ryan.bales Although you can upload and view a V6 Rhino file it does not convert to a Fusion design. I think you need to update your translator to the new file version. I've attached a simple file with a box and a sphere.
Another odd thing is a PDF is created saying there was a partial success, I'm sure in the past if you double click a pdf in the data panel it would open in Chrome but now Fusion tries to open it and fails. Should the option to open\insert be there for PDFs?
Thanks Mark
PS Looks like 3dm is not an allowed file type and you don't get any warnings it's not allowed just nothing happens when you hit post apart from the attachment's removed and you're returned to the post edit page.
Mark Hughes
Owner, Hughes Tooling
ryan.bales
in reply to: HughesTooling
Very interesting. Normally we use the cloud translator if the local one fails. I'll have to pass this on to the team.
Ryan Bales
HughesTooling
By local do you mean New Design From file, because 3dm has never been an option from there. Surprised the viewer works but the translation fails.
Thanks Mark
Mark Hughes
ryan.bales
Using upload from the data panel. Although i imagine the translation is very similar, new design from file is only looking for specific file types.
Ryan Bales
ec2638
To confirm @HughesTooling input, with Rhino 6 files, something ‘happens’ via the data panel and A360, but it is not usable in Fusion - no data/objects...empty.  Rhino 5 files work.
Translation needs to be looked at and fixed to support Rhino 6 .3dm, please.
