Reposition an edge polygon
I create an edge polygon in an arbitrary position on the plane (as far as I can tell, with an edge polygon, the start and end points are one edge, so you cannot start by fixing the origin)
Once the polygon is created, I want to move the centre point to the axis origin, as this will make the rest of my workflow much easier.
I go to Modify / Move/Copy
Move = Object
Move type = Point to point
Origin point = the center of the polygon
Target = Axes origin
OK button is greyed out, so I cannot complete the process.
I am REALLY new to Fusion 360, so I expect that I am missing something.
Brendon
g-andresen
please show the process in a screencast.
günther
TheCADWhisperer
Forget you ever saw Move. (or at least for the next 6 months)
You should be using Coincident in sketch
or
Joints for Components.
Thanks.  Using the coincident worked!
