Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Reposition an edge polygon
3 REPLIES 3
468 Views, 3 Replies
I create an edge polygon in an arbitrary position on the plane (as far as I can tell, with an edge polygon, the start and end points are one edge, so you cannot start by fixing the origin)
Once the polygon is created, I want to move the centre point to the axis origin, as this will make the rest of my workflow much easier.
I go to Modify / Move/Copy
Move = Object
Move type = Point to point
Origin point = the center of the polygon
Target = Axes origin
OK button is greyed out, so I cannot complete the process.
I am REALLY new to Fusion 360, so I expect that I am missing something.
Brendon
3 REPLIES 3
g-andresen
please show the process in a screencast.
günther
TheCADWhisperer
Forget you ever saw Move. (or at least for the next 6 months)
You should be using Coincident in sketch
or
Joints for Components.
in reply to: TheCADWhisperer
Thanks.  Using the coincident worked!
