Remove Avatar from Project Details
Careless_
Careless_
I seem to have some projects in my project sidebar/list that have icons that I may have picked back when I was exploring the web UI.
I was attempting to remove it just now so that all my projects show as the default triangle with dots/nodes and noticed that this option isn't available?
Editing the Avatar for a project only allows a user to select their own image or one of the pre-existing ones, and this can't be removed completely to restore the default.
Perhaps an option to remove avatars from projects is a simple enough UI option to add?
Not important, just a thought.
g-andresen
1. copy the "triangle" and save it locally
2. upload it into your project
3. after updating it also appears in the datapanel
This process is necessary for every project that should get this "logo" afterwards.
günther
Careless_
How do I "Copy the triangle" original file.
where is the actual image file located on macOS?
or am I just copying the web panel version of the image?
g-andresen
rightclick image > save as (location) > ok
günther
Careless_
Thanks Guenther,
I've attached the default_group.png in its full size in case anyone needs to use it in the future.
Also, I noticed that the thumbnail needs to be uploaded every time. It would be nice if F360 Hub could save previous uploads associated with the account so that repeat icons do not need to be uploaded all the time.
Perhaps it may be in a small update in the future.
