Rectangular pattern won't align hexagons
Hi Support,
Fusion will not align a hexagon of 7.1mm side length when doing a rectangular pattern, for either in sketch or body.  If I change the side length to 7.101 it aligns correctly and objects can be combined.
Replies (23)
g-andresen
follow @TheCADWhisperer  and define a different length
Screencast
günther
jeff_strater
@TrippyLighting wrote:
What do you see when opening the file I had attached ?
If you had used "all digits" when copying the measured value you'd see the same result and there's no problem.
3 digits accuracy is OK for manufacturing purposes, but in this case you'll have to adhere to the precision the CAD system requires to operate properly.
A note on this:  We recently fixed a bug (not released externally yet) in the measure capability within a command.  As @TrippyLighting pointed out, today, that measurement is limited by the setting you have in the Measure command.  The bug fix was to not apply that truncation when doing the implicit measure from the "three dot" measure in an entry field.
Now, you will get the full accuracy of the distance between the objects.
However, and I cannot say this strongly enough, using Measure here will not fix the underlying parametric problem.  Measure is still a constant value, and will not update when you change the side length of the hexagon.  You would have to edit the pattern and re-measure the distance each time you change the side length.  Using the formula here or changing how you specify the hexagon length will make the sketch fully parametric.
Jeff Strater
Engineering Director
TrippyLighting
@Anonymous wrote:
Are you saying its a rounding error due to 3 decimal point spacing?
No, it's an error by the designer!
As evidenced by using a mathematical formula to calculate the needed distance precisely, the design/sketch works just fine.
Thank you all who responded.  I now understand parametric evaluation is required for correct spacing.
Since Fusion evaluates this for you using the "non-optimal" measure approach, I just assumed that it carries full precision, even though it displays 3 decimal places.  I see full precision preserved for linear dimensions on hover, even though it displays less.
I also acknowledge that this "issue" has been fixed and waiting release.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
