Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Problems with Scaling Up A Model (Help Appreciated)
1 REPLY 1
233 Views, 1 Reply
Hi, I'm a student still learning how to use the program. I am having issues trying to scale up a model I made. I want to scale it up to a factor of 1.4, but whenever I select the model and click "scale", it doesn't allow me to. Does anybody have an idea of what I can do? Any help is much appreciated! It would be great if somebody could help me solve this problem, thanks a lot!
Link to the .f3d file attached below.
1 REPLY 1
jhackney1972
You model is made of mostly bodies and one component.  For an assembly, this is odd.  Normally you should have all components with the bodies related to them under each along with the body sketches.  Anyway, follow the Screencast and you will not have any difficulty.  By the way, make sure that you have Select All checked under Selection Filters.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Technology Administrators
