Dear Autodesk Team, here is my problem.
I cannot see my construction lines in dashed form when I export my sketch as DXF file.
I have created a sketch with a few lines some of which are construction lines.
However, when I insert the DXF file into the same project, I see that all lines are solid lines, i.e., the construction lines are no more dashed. Actually, I am creating a project that I read DXF files in Python and process them depending on their types.
I need help in this direction.
bkarpuz
This is normal behavior when exporting/importing DXF.
Copy / Paste instead
1. select elements in active sketch > rightclick > copy
2. paste into another ( or new) sketch
günther
@basak_karpuz As Fusion's sketch environment doesn't support line types for import or export you might have to create your own export add in, does Fusion's API let you read line types?
Even if AutoDesk wanted to improve how sketches read\write line types it's not likely to happen for a long time.
Mark Hughes
Owner, Hughes Tooling
