Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
PMI
6 REPLIES 6
info
404 Views, 6 Replies
PMI
I'm trying to open a step file created from Creo (with AP242) and PMI data, but unable to import the PMI data from the file?
I have checked the box PMI in preferences.
There're a lot of settings in the Creo AP242 protocol. Can be that this is causing the issue.
Does anyone has a solution for this issue?
6 REPLIES 6
MRWakefield
in reply to: info
I've not had any experience with this personally but does this page here help at all?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
___________________________________________________________________________________________________________
I've created a Windows application for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
info
in reply to: info
Thank you!  I have red that one. I does not contain a sample or else to verify the funtionality. I probably need to try some options with Creo AP242 export??
MRWakefield
in reply to: info
Ok, sorry it wasn't much help. Hopefully someone else here will have more experience with this.
Marcus Wakefield
MRWakefield
in reply to: info
There's also a NIST STEP File Analyzer and Viewer which might help.
Marcus Wakefield
info
in reply to: MRWakefield
Hello Marcus,
I already downloaded the NIST application and it helps visualizing the issue.
I'm making some small progress with Creo Ap 242 export files, but not yet there!
Thanks for the help so far!
MRWakefield
in reply to: info
Thanks for the update 😊. Good to hear you're making progress.
Marcus Wakefield
