parameter dialog box not showing up
Message 1 of 44
Hi there,
I encountered a pretty weird issue today when I tried to edit the parameter from the "change parameter" function. When I clicked the "change parameter" button, the parameter dialog box did not show up.
This is a video to help better illustrating what I was describing: https://screencast.autodesk.com/main/details/ae7c1770-ea17-4c77-9f76-2e350ccb9728
Your help is much appreciated!
Jason
Accepted solutions (3)
Replies (43)
Message 2 of 44
keqingsong
Do you use a second monitor as an extended screen or just one?
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 44
I'm using a single-screen laptop!
Message 4 of 44
It functioned perfectly the day before
Message 5 of 44
keqingsong
That's odd. Could it be possible that it's behind the active Fusion 360 window? Sometimes you can wrong into weird window over windoe behavior. Just want to rule all the possiblities out before we dive deeper.
Keqing Song
Message 6 of 44
How to tell? I tried dragging the Fusion360 window around to see if any windows are "hiding" behind it. I also tried miniziming the Fusion360 window and nothing was found. I also tried uninstall and reinstalled Fusion360 but it did not change anything. 😞
Message 7 of 44
keqingsong
Try to reset to default layout...let me know if this fixes it.
Keqing Song
Message 8 of 44
It did not!!
Message 9 of 44
keqingsong
Can you tell me what the build number is? Go to the Help icon > About to see.
Keqing Song
Message 10 of 44
not sure if this is the number you were asking for
Message 11 of 44
keqingsong
Got it. Can you share some machine specs?
Keqing Song
Message 12 of 44
I'm sorry I'm not quite sure what you meant by machine specs, but if you were asking what kind of computer I am using .... attached is a screenshot of the system info I got from control panel, let me know if this is not what you want.
Message 13 of 44
keqingsong
Ok this helps. Have you restarted your computer after the reinstall?
Keqing Song
Message 14 of 44
Yes I have!
Message 15 of 44
keqingsong
Do you have some time to do a skype session? Email me at keqing.song@autodesk.com and let's see what is going on.
Keqing Song
Message 16 of 44
Hi Keqing,
Sorry to get back to you this late. I just sent you an email. Would you be available for the skype session sometime tomorrow? I really want to solve this as soon as possible.
Jason
Message 17 of 44
venkitr
May be would be useful if you could share your display settings.
Open Display in Control Panel
Not sure - but could it be related to High DPI
Rajesh.V
Fusion 360 Developer
Link Name | Link Name | Link Name | Link Name
Message 18 of 44
Hi there,
Keqing helped me solve this issue through a skype session although the exact reason causes this is still unknown.
Thanks for your reply all the same!
Jason
Message 19 of 44
keqingsong
It may be due to the parameters window being dragged way off screen that we couldn't see it. We ended up clearing user cache data and then restoring settings to default, restart, and that fixed the issue.
Keqing Song
Message 20 of 44
skrubol
I'm having this same issue right now.  Not sure if it's due to yesterday's update or not.
I've got a full HD screen and never use a second monitor on this system.  Tried rebooting PC, clearing user cache, restoring defaults in preferences, reset to default layout followed by restarting Fusion and still no luck.
EDIT:  Weird, cleared user cache, this time it came up with the tutorials and stuff (which it didn't before,) and seemed to fix the issue.
