parameter dialog box not showing up
Message 1 of 44
Hi there,
I encountered a pretty weird issue today when I tried to edit the parameter from the "change parameter" function. When I clicked the "change parameter" button, the parameter dialog box did not show up.
This is a video to help better illustrating what I was describing: https://screencast.autodesk.com/main/details/ae7c1770-ea17-4c77-9f76-2e350ccb9728
Your help is much appreciated!
Jason
Accepted solutions (3)
Replies (43)
Message 21 of 44
Hi there!
Actually my issue was exactly the same as yours i think, but Keqing contacted me via skype several days after the issue and we clear the cache and restore default again and restart it, and that solves the issue. I'd suggest you wait for a day or two and then try to clear and restore everything again. If that doesn't work, you should get in touch with the autodesk folks!
Message 22 of 44
I'm having this same issue, resetting views and clearing cache hasn't fixed it either.
What else can I do?
Message 23 of 44
I actually have no ideas. I would recommend you to clear your cache AND restore the settings to default and then restart the program. I'm pretty sure there is a weird and mysterious bug in Fusion360 ....
Message 24 of 44
I tried all that and restarting my computer as wel...
Didn't mean to just reply to you, meant for the whole thread. Thanks for the tip though!
Message 25 of 44
I think you could arrange a skype meeting with the Autodesk people and see if they can help @keqingsong
Message 26 of 44
I'm having the same issues with the parameter window, is there anything else I can do outside of restoring defaults and flushing user cache?
Message 27 of 44
keqingsong
Try doing a "Restore Default Layout" and restart. See if that brings it back.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 28 of 44
I actually sorted it out. Plugged in an external monitor and the parameter window appeared on it.
Dragging it back onto my laptop screen has resolved this issue.
Message 29 of 44
whunter
Same is happening here, I have a docking station at work and home, monitor layout is different though.
I'll see if the dialogue is restored when I'm at work tomorrow. Not nice Smiley Frustrated
Message 30 of 44
whunter
Yes, confirmed, my parameter dialogue is now back.
Windows 7 Pro, 64-bit SP1, Quadro K610M graphics card, DirectX 11.
Message 31 of 44
adam.filipowicz
Im running into this same issue
Running win 10 64 on Dell precision
I have triple monitor setup
I cleared user case
reset to default layout
Even on a new document it will not show the change parameter window
no other software running. the screen isnt behind anything.
very frustrating as I need to make a change in my design.
Message 32 of 44
HughesTooling
Have you tried first click the modify parameter icon then press alt+space at the same time then press the m key next press one of the arrow keys, then move the mouse and the dialog should snap to the mouse pointer.
Mark
Edit I should have said click the parameter icon first the try the procedure above.
Mark Hughes
Owner, Hughes Tooling
Message 33 of 44
adam.filipowicz
Yes this worked. it was hidden off the left side of my left monitor.
I never moved it, wonder why it went over there.
Message 34 of 44
I think this is a weird bug of Fusion360..I didnt even have a dual screen!
Message 35 of 44
HughesTooling
It seems to be a problem with multi-monitor setups, seems to be a problem if you change the amount of monitors you're using even having a different setup on 2 computers.
Mark
Mark Hughes
Message 36 of 44
patrick.miller
Mark - thanks for the timely workaround.
Adam, Jason, etc - We plan to have an update before the end of May that includes a fix for the parameters dialog. After the update, the parameters dialog detects if it is not visible and centers on the active monitor. Most often this happens when the dialog is dragged, moved, magically beamed to a monitor that is no long available.
Please let me know if you still see problems with the parameters dialog after the May update.
Patrick Miller
User Experience Designer
Fusion 360 Learning
Message 37 of 44
Thank you for the update!
Message 38 of 44
"first click the modify parameter icon then press alt+space at the same time then press the m key next press one of the arrow keys, then move the mouse"
This worked perfectly for me, thank you.
Message 39 of 44
eshahar
Observer
Observer
Just happened to me too. Restarted, deleted cache, reset layout - did all of these multiple times. Still doesn't work.'
EDIT: Missed the second page of this thread... this solved it:
Message 40 of 44
x3msnake
This solved my issue Thanks 🙂
What happened was i was logged in in a PC with multi monitor and ended putting the param box on the second monito, looks like it propagates when you re-login in a station with only one monitor
