Since the latest update where is switched to SpaceMouse SDK V.4.0 the older 3D mouse that only work with driver version 10.4.10 or lower don't work anymore. Would it be possible to give people the posibility to switch to the older version in the preferences or another way to get them to work?
I spoke with 5 different people for who it stopped working and there are probably a lot more, the old 3D mouse are build really solid and after 14 years mine is still as good as new except for the driver. I did have contact with 3Dconnexion but they can't do anything on their side.
(I'm using a 2007 SpacePilot)
Solved by Phil.E. Go to Solution.
I am one of the ones that was discussing this problem on the FB group. This is a real problem for a lot of us, its not really in the budget to buy a new 3d mouse over an API issue.
Yes I'm in the same boat with a 2005 space mouse usb 5000 its still a great navigator besides being a little out dated. It still works in Inventor, Blender, Z brush and other 3d software please find a patch or a work through a lot of people using fusion 360 are learning and can't really justify spending money on a 300 dollar navigator when they have a perfectly working navigator already.
My SpaceExplorer (2007?) has also effectively bricked, it acts as a scroll wheel, and the panel button brings up the 3dx menu for inventor, even if I remove it via the install tool
Same goes for me, started using F360 and my Spacepilot after some months off, buttons working fine, no joystick action in the program, works fine in the 3dConnexion demo though, Please advice Autodesk.
Best Regards, Tom
i have a newer 3d connexion enterprise... same issue all buttons work except the space mouse itself. why!?!?!?! i need to get work done!
I'm in the same boat. Downloaded the two legacy drivers, removed everything, uninstalled, reinstalled. Space explorer not working in fusion, at all. works just fine every where else. I noticed in the feature preview that there was a 3d mouse update coming. i enabled it and my SE stopped working. disabled it, worked fine. now after the last update. doesn't work at all, and i noticed the 3d mouse feature has been removed from preview. so i assume now its live in the program.
either way, its a real pain to not be able to use this... Be really nice to get this working.
Hey, got a fix that has worked so far.
use driver 10.6.3. it won't show up under the space explorer, its under the space pilot pro. as soon as i installed that driver, everything works as normal. this is the latest driver, came out in 2019. so far so good. good luck, hope that helps.
this driver doesn't work with the old spacepilot and other old 3Dconexxion devices, to be clear I tried all drivers that are available to make sure that isn't the problem.
Can someone from autodesk at least reply so we know if we need to buy new 3D mouses or if there is a chance that they will work again?
This 10.6.3 version fix did work on my workshop pc, but not on my inside one. It my be a difference in the Windows update status. I have not pinned it down yet.
I would really appreciate a quick fix for this also.
Thanks.
Autodesk made a separate post regarding this issue and looks like it should be solved with the next update
https://forums.autodesk.com/t5/fusion-360-support/fusion-360-support-for-older-3dconnexion-spacemous...
I completely uninstalled all the drivers then did a fresh install, have you updated your other machine where it wasn't working? Someone mentioned in this thread that autodesk is working on a fix and should be resolved in the next update. not sure, so far mine is still functioning properly with the driver I mentioned. I update my windows regularly and I recently switched to windows 11, though the issue started in windows 10.
I tried again after reading your message.
Fusion 360 updated and closed.
Uninstall 3d connection driver and rebooted Win 11 also up to date.
Installed archived driver 3DxSoftware64_v3-16-3_r1447 for my 12 year old SpacePilot that was working just fine before Fusion update that killed it. Works fine still with other programs.
Reinstalled above driver and it still does not work in Fusion 360.
Used update wizard in driver menu to update to 3DxWare64_v10-8-4_r3407 after uninstall.
Now it does not work in Fusion 360 or within the new driver settings menus of 3d connections. It also lists the Space Pilot now as a mouse. I can start and stop driver to no avail.
Uninstalled 3DxWare64_v10-8-4_r3407 and reinstalled 3DxSoftware64_v3-16-3_r1447. Now works within it's on menus but still not in Fusion 360 of course.
I will watch and wait for a solution.
There is an update to Fusion 360 to address the following issues for customers using Windows:
The update includes a new preference to use the legacy 3Dconnexion drivers for the experience of the previous integration between Fusion and 3Dconnexion devices. If you have an older device, it should be supported by the Legacy driver setting in Fusion.
Note: This will also remove the newest features like constrained orbit, and advanced button customization features, but only temporarily. We are currently working with 3Dconnexion on a solution for the sketch pan/zoom behavior that is intended to provide both the latest functionality as well as options for sketch behavior.
To get the latest build:
To get the Legacy driver option:
Thanks for improvements.
Question: the new behaviour is NOT to allow 3D rotation/orbit via spacemouse when in sketch. Can this be an option ? (workaround is to press shift and middle mouse button).
We are currently working with 3Dconnexion on a solution for the sketch pan/zoom behavior that is intended to provide both the latest functionality (like constrained orbit and Fusion 360 command support) as well as options for sketch behavior (to turn off/on the pan/zoom behavior).
