Fusion crashed,
Reload, brings me here,
Click on Sign in and nothing happens.
It's a work day....
Solved by RajkumarIlanchelian. Go to Solution.
@davebYYPCU @I have asked Jane to continue to get information here.
Can you right click on the short cut and run as an administrator? Far shot but I want to eliminate that one.
for the short term if you create a quick and new user profile and install Fusion it should 100% work while we can try to figure out what is happening here.
if you are not using any other Autodesk products can you try to uninstall all of them but Fusion 360?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
New reinstall was about 2 hours ago, before this restart.
Restart Windows, no internet connection, 3 minute idle, Task Manger shows this, for autodesk stuff.
Run Fusion as admin, (offline) no positive result, not responding.
Connect to Internet, Run as Admin, no positive result not responding. But the Analytic Client Service, reduced to one process from 3, as above.
From image you provided previously, looks like you've signed in correctly. Did you navigate to this page after logging in from Fusion or Inventor? Sorry this is Jane replying from a different computer where this user account is logged in.
I am not sure what happened in what order any more.
Identity manager was not on my system when I was asked to download it, I have not deleted the dB file, after fresh install of Identity manager.
That set of pictures - the larger black one happened whilst starting Inventor, I clicked on go to identity manager, and Inventor start running, but that was first time to see an intervention page.
should I clean uninstall both Fusion and Insider?, I don’t need insider anyway.
@davebYYPCU Certainly start with removing everything that you think you won't need. It seems like there I a mix of things going on here. Removing one product at a time and trying out Fusion would be the best way to see which one is interfering and then can find out why.
Autodesk Fusion
Join Fusion Insider
Deleted the db file.
Launch Fusion, no response, splash screen not responding.
Uninstalled Insider.
Uninstalled Fusion
Checked AppData, and deleted Fusion 360 folder and Autodesk Fusion 360 folder.
Opened A360 and account shows a long list of Fusion Apps.
Weirdness got worse,
Attempt to Install Fusion 360, from A360 yellow banner
downloaded an installer (3rd copy now)
Complained that multiple installers were running, past that and installer started,
setting up progress bar got to 41% and backtracked to 38 %, jumper a little at 50%, and failed about 80% second time, because it backtracked to 76% and then failed at 80% or so.
referred me to a streamer log. attached.
@davebYYPCU @Can I ask if there is any chance that you can uninstall all Autodesk applications including AutoCAD and Inventor. Goto Appdata and delete the entire Autodesk folder. Restart your computer and now install only Fusion 360.
Autodesk Fusion
Join Fusion Insider
Deleting all other products? Means I will have to download them again.
that done, I am presented with this screen first time, ticked the box,
second boot of fusion did not take me there, and bonus you have my menu settings saved somewhere, thanks.
@davebYYPCU Does this mean Fusion is now working or you are still seeing the same problem. I assume you have removed all the Autodesk products and starting from ground up?
Autodesk Fusion
Join Fusion Insider
Not solved,
Somehow I have Insider installed. Not compatible with normal files.
@davebYYPCU OK.
1. Not solved even after removing all the other products? (or you have not removed all products yet)
2. Uninstall Insider
3. Delete your installer file on disk (likely you used the Insider installer to install)
4. Get Fusion 360 from your accounts page and install it.
Are you now stuck in the launch page or you got to the sign in page and you are not able to move further?
Autodesk Fusion
Join Fusion Insider
