Fusion Support
motion study joints interference
3 REPLIES 3
mjadams
147 Views, 3 Replies
I'm trying to use motion study to test a simple mechanism for further development, it involves revolute joints and a motion link. when I go into motion study the motion link is disabled and when I try to edit the second revolute joint it causes the first edit to chance and get erratic steps in the motion profile. I've draw this and similar mechanisms numerous times and always I get the same issue with motion studies. I'm new to motion study so I may be doing something wrong but the only issue I have seen similar in the forums involved contact sets. I am not using those and cant find any active. I have simplified the mechanism to a few basic parts but I still get the same issue. its really got me stumped.
the jump is the issue i did not add that and there is no point attached to it to edit it. revolute 2 and 4 should be motion linked.
the motion I am try to simulate is like this
3 REPLIES 3
jhackney1972
in reply to: mjadams
Please attach your model.  The Forum users cannot possibly help you for just pictures.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
mjadams
ok will do
mjadams
looks like its a problem with the joint between the lifting arm and the grounded bracket. the joint seems to see the cog as part of the bracket. I replaced the joint with a cylindrical joint and left a gap and it behaving better. the motion link is still not right though I have to control the joint on the cog with the spike to keep the spike level. if the motion link was working levelling could be done by holding the base cog still
