Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
no access to files from cloud
2 REPLIES 2
184 Views, 2 Replies
Two files out of my project are unable to open, with no visible reason. I was already trying for 2 days, so now I contact you.
2 REPLIES 2
jhackney1972
What if you access your project from the Web database (A360) and try to export the files from there to your local drive?  If you can do this, then you can replace the ones on the cloud database.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
in reply to: jhackney1972
Then following error appears:
[cid:0098f19e-a51b-4749-9182-1cc093db260e]
