I was not able to download the admin installation file of Fusion. It redirects to the Client Downloader instead. Neither wget, nor curl work.
Windows Admin installation (old link):
https://dl.appstreaming.autodesk.com/production/installers/Fusion%20360%20Admin%20Install.exe
Macos Admin Installation (old link):
https://dl.appstreaming.autodesk.com/production/installers/Autodesk%20Fusion%20360%20Admin%20Install...
Because of name change from "Fusion 360" to "Fusion" the links are not working anymore. So just remove "360" from the link name.
Windows Admin installation (new link):
https://dl.appstreaming.autodesk.com/production/installers/Fusion%20Admin%20Install.exe
Macos Admin Installation (new link):
https://dl.appstreaming.autodesk.com/production/installers/Autodesk%20Fusion%20Admin%20Install.pkg
Maybe this will be helpful for someone.
Solved by mikeh361. Go to Solution.
@radiophysique @Thank you for reporting this. I will work with our engineering team on this and report here shortly.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@radiophysique I have sent you a DM with the correct url until we address this on our side.
Autodesk Fusion
Join Fusion Insider
Thank you for this. I've been pulling my hair out (if I had any) since yesterday. And trying to navigate around the Education website is painful. Nothing matches what they say it should match. Not sure if my account is as an IT Admin or Educator and there's no way to tell. Or if that's the reason things to look right.
Hello, will the link to the new Admin Installer be published ?
We need it urgently.
Thanks in Advance
@hageXEK5Y @It already is. You redownload from your account and it should be the new installer.
Autodesk Fusion
Join Fusion Insider
