I installed these as ttf and they work in any other program. I need them for a customers design, ASAP
yes, I restarted my Pc twice already. I've restarted fusion a total of 4 times. Even with Sweet child installed as an OTF, it did not show up.
https://www.dafont.com/bubblegum.font
https://www.dafont.com/sweet-child-script.font
You do not want to use TTF fonts, Fusion 360 prefers OTF fonts. I converted both to OTF and they load perfectly into Fusion 360. You must be sure to restart Fusion 360 after installation of the fonts. Zip file of both is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
I do not know what you want to use these fonts for but I cannot get Fusion 360 to use them for any type of feature including Emboss, Extrude, etc. I cannot even Explode them which usually allows you to use them. Good Luck.
John Hackney
Retired
@jahnj0584 Try downloading QCad and convert then save to DXF. Think you get 100 free saves before you have to buy QCad. I tried it in the past and it did a good job with fonts Fusion didn't like.
Mark
Mark Hughes
Owner, Hughes Tooling
Not sure why these are failing, both work fine in Rhino and the quality looks quite good compared to some fonts. @jeff_strater Could these fonts be looked at for improvement?
Mark Hughes
Problems and different behaviour with these fonts do not seem to be limited to Fusion.
1. the fonts are not available in Inkscape and Gravit Designer after installation and restart.
2. Text created in V-Carve pro and imported as SVG in Fusion are both extrudable.
günther
