Hi, All the zoom and pan options have changed and I'm not sure what I must have pressed. I'm using a mac and used to be able to to rotate when pressing shift and moving two fingers on the track pad and now this does not works anymore. Thanks in advance.
Solved by paul.clauss. Go to Solution.
Hi @Anonymous
Thanks for posting! The preference to change navigational commands is in your general preferences, as shown below:
You can learn more about these settings at this link - I hope this helps!
Hello , you can change the settings . Go to preferences and then change the setting . See the image , I have marked It .
