Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Moving around
2 REPLIES 2
470 Views, 2 Replies
Moving around
Hi, All the zoom and pan options have changed and I'm not sure what I must have pressed. I'm using a mac and used to be able to to rotate when pressing shift and moving two fingers on the track pad and now this does not works anymore. Thanks in advance.
2 REPLIES 2
paul.clauss
Hi @Anonymous
Thanks for posting! The preference to change navigational commands is in your general preferences, as shown below:
You can learn more about these settings at this link - I hope this helps!
Paul Clauss
Product Support Specialist
sanket223.patil
Hello , you can change the settings . Go to preferences and then change the setting . See the image , I have marked It .
Sanket Patil
Mechanical Engineering
Expert Elite
Technology Administrators
