When making a drawing from design (Title blocks too), if you have a sketch with more than one object and you go to move it, and you right click to select 'End Point' or any of the other options, and use that as your reference to move from, only one of the objects will move. This has always happened since I've used Fusion, about 3yrs now.
The bug only seems to move the most recent sketch item, rather than the entire selection
The video also shows a newer bug, when in sketch mode, straight lines don't display properly when not zoomed all the way out. Only the endpoints are visible, same goes for parts themselves, this bug is much worse than the one posted. I'll get around to make a post soon if it isn't fixed
