Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Model shows as line drawing rather than an solid
3 REPLIES 3
mick_d_dunne
160 Views, 3 Replies
Fusion was working  fine, but I guess I hit a hotkey or something in error and now my models show a line drawing after extrusion rather than a solid. This even happens when I load a model from a previously saved file that was ok.
I have re-installed fusion but am still having the same problem. I attach a screenshot from the model I am currently working on which was taken immediately after extruding the fully defined drawing.
3 REPLIES 3
jhackney1972
in reply to: mick_d_dunne
You can start by checking this setting to make sure you are not on Wireframe.
John Hackney, Retired
mick_d_dunne
Problem solved!
Thanks a lot John,
Mick
g-andresen
The “Accepted solution” mark is given to posts that have offered clues to the solution.
This was the hint from @jhackney1972 .
Please change the assignment.
günther
