I have made very simple design and would like to mirror the holes from white body to the red body. I choose mirror, features, adjust. It gives error: No pattern instances could be intersected with the original body. Try adjusting the pattern settings, or changing the selections.
The problem is I can't mirror the whole body because I need to mirror the holes from yellow body as well to the red body.
Is there any solution to mirror just features.
File is attached below.
Thank you for your help in advance.
Solved by g-andresen. Go to Solution.
The mirrored feature can only be created on the same body as its origin.
günther
Hi @g-andresen,
But in this case, what is the solution what you would use in this instance? How would you get the holes to the other body? Start new sketch on middle body and project holes there?
Thank you.
