It looks like the Finish Soothing tolerance overrides the minimum cutting radius. If you set them both to 0.005 it seems to work.
Mark Hughes
Owner, Hughes Tooling
Thanks. I can not set the tolerance to 5 thou on this part.
It's not the tolerance it's the Finish deviation tolerance. If you copy the OP and edit one and change the finish deviation you can double check if there's a problem.
Mark
Mark Hughes
This shows the difference. Light blue is your original toolpath, looks like only the offset toolpath is affected.
Mark Hughes
