Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Minimum Cutting Radius value being ignored
4 REPLIES 4
FrodoLoggins
189 Views, 4 Replies
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
4 REPLIES 4
It looks like the Finish Soothing tolerance overrides the minimum cutting radius. If you set them both to 0.005 it seems to work.
Mark Hughes
Owner, Hughes Tooling
Thanks. I can not set the tolerance to 5 thou on this part.
It's not the tolerance it's the Finish deviation tolerance. If you copy the OP and edit one and change the finish deviation you can double check if there's a problem.
Mark
Mark Hughes
This shows the difference. Light blue is your original toolpath, looks like only the offset toolpath is affected.
Mark Hughes
