Hello all,
I've been googling around but nobody seems to have the same problem. I cannot seem to find Mesh to Brep in this menu, also not in the search. What else can I try to Combine using these meshes?
Helmer
Solved by HughesTooling. Go to Solution.
Hi Günther, thanks for the reply
This is what I get..! I must have a weird experimental version? It says 2.0.6231, Startup license in About.
@g-andresen Are you in direct mode or timeline mode there?
@helmerdewitte If you have the timeline you need to create a base feature then with it active select the mesh and right click. Or you need to be in direct mode and lose your history.
Mark
Mark Hughes
Owner, Hughes Tooling
File>Export and then Attach your *.f3d file here if you can't figure it out and someone will create a video solution.
Make sure that mesh preview is on:
EDIT *and design history disabled*
Then its under modify in the toolbar:
It was the missing Base Feature. As a total noobie of course this doesn't speak for itself for me...
Thanks Ryan and all of you, but Hughes won this round 🙂
