Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Mesh to Brep removed?
8 REPLIES 8
Message 1 of 9
helmerdewitte
3986 Views, 8 Replies
Hello all,
I've been googling around but nobody seems to have the same problem. I cannot seem to find Mesh to Brep in this menu, also not in the search. What else can I try to Combine using these meshes?
Helmer
8 REPLIES 8
Message 2 of 9
g-andresen
in reply to: helmerdewitte
Hi Helmer,
try this:
günther
Message 3 of 9
helmerdewitte
in reply to: g-andresen
Hi Günther, thanks for the reply
This is what I get..! I must have a weird experimental version? It says 2.0.6231, Startup license in About.
Message 4 of 9
@g-andresen  Are you in direct mode or timeline mode there?
@helmerdewitte  If you have the timeline you need to create a base feature then with it active select the mesh and right click. Or you need to be in direct mode and lose your history.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
File>Export and then Attach your *.f3d file here if you can't figure it out and someone will create a video solution.
Message 6 of 9
Hey wait the Base Feature did something...
Message 7 of 9
ryan.bales
Make sure that mesh preview is on:
EDIT *and design history disabled*
Then its under modify in the toolbar:
Screen Shot 2019-08-23 at 12.47.22 PM.pngScreen Shot 2019-08-23 at 12.47.28 PM.png
Ryan Bales
Fusion 360 Product Support
Message 8 of 9
helmerdewitte
in reply to: ryan.bales
It was the missing Base Feature. As a total noobie of course this doesn't speak for itself for me...
Thanks Ryan and all of you, but Hughes won this round 🙂
Message 9 of 9
Thank you I was having this issue and this helped so much!
Technology Administrators
