Many users have already reported issues about the memory consumption of Fusion 360.
There is a memory leakage with command inputs. See screencast below.
My machine: Windows 7, i7-37770K, RAM 16GB, NVidia GTX 960 (lastest driver 430.86)
I tried with Extrude and Pattern, but the issue should be the same with other commands.
The memory consumption is monitored with this add-in: MemoryUsed add-in for Fusion 360
I agree that nobody plays with the control like I did in the video but as you can see, Fusion consummed 24MB of memory. Furthermore, it should release most of these 24MB when I clicked the OK button or when I deleted the body.
Thank you.
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
When did the problem arise? They must resolve this serious mistake as soon as possible.
