Fusion Support
Manufacturing vs Design origin
3 REPLIES 3
crchisholm
264 Views, 3 Replies
I've run into this problem a few times and somehow manged  to figure it out, but with my sieve for a brain, I can't find the solution.
In the design, I have the origin in the right spot, but when I go to manufacturing, it shows two origins....the larger where I want it and the smaller in the middle.  I have spent the last hour trying to figure out how I got there before, but with no luck.
If someone will remind me of how to get the manufacturing origin to the LL corner as it should be, I promise I will print it out and paste it to my cornea.  (or maybe my wall)
Pic attached
Thanks (and apologies) in advance
3 REPLIES 3
HughesTooling
in reply to: crchisholm
The copy of the file I have from your other post has all the origins at the centre. Can you share the design in the state you have it now?
You can set the origin in the setup without moving the model around. Also don't attach pictures, just paste them into your message.
Mark Hughes
Owner, Hughes Tooling
seth.madore
Well, there's a slight annoyance when the Origin is in the same spot as where you want your WCS origin to be.
I've also attached this as a file you can download and watch again as needed
Seth Madore
crchisholm
Once again, you have patched me up.  I have saved your video to my desktop.  Thank you very much.
