@DG_Fusion The logs shows that you are on a very old version of Fusion 360 2.0.15775
Can you please do the following:
1. Close Fusion 360
2. Delete the shortcut that you are using to launch Fusion 360 (Important)
3. Go to Add/remove Programs - Select Fusion 360
4. Modify
5. This will launch the Fusion service utility
6. Uninstall Fusion 360/Re-install Fusion 360
7. This will take you to the latest version
8. This will also generate a new shortcut that you can use for launching the program
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
