Announcements
Manufacture Simulation - cannot fully turn off tool
cyberreefguru
cyberreefguru
In the most recent update, you can no longer fully turn off the tool when simulating.  There is a magenta square where the tool contacts the material when the tool is "turned off".  The tool shows properly when turned on.  See screencast.
Professional PowerPoint Jockey...
jhackney1972
Screencast is missing.  If you have issues getting it to insert, just use the Link tool.
John Hackney, Retired
cyberreefguru
doesn't seem to be a way to edit the post.  here's the screencast.
MoshiurRashid
Still there is no screencast. I think you should post this in the manufacturing forum if it is CAM related.
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
cyberreefguru
I just wanted to do is post the bug report - when I add the screencast, all I get is:
"Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied."
There has to be an easier way.
