Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Mach3 post processor spinal on
3 REPLIES 3
jimjax
398 Views, 3 Replies
I have been using Vcarve pro but now want to use Fusion 360 for milling. I can get things to work but can not find how to turn the spinal on-off and the vacuum on-off.
For me the Spinal on is M03 and off M05, vacuum on M07 off M09
I am enclosing the Mach3 file I am using
Labels (1)
3 REPLIES 3
Arun.rs
in reply to: jimjax
Hi @jimjax
Thanks for posting your query.
I could not get the 'spinal on-off' codes. M03 and M05 codes are associated with Spindle ON and OFF codes which are already activated in Mach3 milling post.
About vacuum On Off code, you can use coolant type as 'Mist' in F360. Refer below.
For detail info about the post editing please refer the  FAQ link
Hope this helps!
Regards
Arun.RS
Technical Consultant - Post Processor
jimjax
in reply to: jimjax
thanks for the helpful reply
sorry my spell checker used spinal instead of 'spindal'
Jim
jimjax
in reply to: Arun.rs
Thanks for your helpful reply
Sorry my spell checker used 'spinal' instead of 'spindle'
