Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
lost Applicationbar and Profile and Help Bar.
8 REPLIES 8
Message 1 of 9
jbg.koop
935 Views, 8 Replies
I don't now wat happend but I lost The Applicationbar  and The Profile and Help Bar.
Is there someone who can tel me how to solve the problem?
in advance many thanks and sorry English is  not my native language
Jan
8 REPLIES 8
Message 2 of 9
masa.minohara
in reply to: jbg.koop
Hi @jbg.koop,
Thank you for posting! I am sorry to hear about the issue. I had some customers who were experiencing the same issue and clean uninstalling and re-install of Fusion solved the issue. Could you try that to see if that helps?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 9
jbg.koop
in reply to: masa.minohara
Hello Masanobu Minohara thanks for your reply.
I already tried reinstalling twice using the normal windows way and I just tried it with the Fusion 360 cleaner tool for windows,
sadly nothing chanced.
I hoop there is an other solution?
Message 4 of 9
masa.minohara
HI @jbg.koop,
I am sorry to hear that the issue still persists. Could you try manual clean uninstall to see if that makes a difference?
Masanobu Minohara
Message 5 of 9
jbg.koop
I did the manual cleaning and even brought my computer back to de state wen it came out of the shop, but it didn't help
i think it has something toe doe whit my personal account
Jan Koop
Message 6 of 9
I have similar problem with top bar. I run windows 10 and got "error 87" when starting windows. This happened about 6 weeks ago and since then I have the problem. Sounds familiar ?  Am now trying to update the driver of my AMD graphics card, which is said to cause the "87" problem.
Maarten
Message 7 of 9
masa.minohara
Hi @jbg.koop,
Thank you for your response! I am sorry to hear that the issue still persists. Does it make any differences if you hit [Ctrl] + [Alt] + [R] after opening Fusion?  I'm not sure if this is actually related to your account but would you be able to create a new Autodesk account and log in to Fusion with a new one to see if that makes a difference? Closing Fusion and then deleting the Login State.xml  will force you to sign in to Fusion again when launching next time.
Windows OS
1. (Close Fusion 360) In windows explorer browse to  %localappdata%\autodesk\web services
2. In the Web Services directory, right lick on the Login State.xml file and select delete
3. Restart Fusion 360
Masanobu Minohara
Message 8 of 9
Maarten
thanks for your reply, I dit update the graphics cart but that din't solve the problem.
but it dit help to get lost of an error message.
I created an new account and that helped
Jan
Message 9 of 9
Masanobu Minohara
thanks for your help
Jan
