After i installed fusion 360 it does not start. it says there is a problem why it was logging in.
Solved by baribak. Go to Solution.
Sorry to hear of the trouble. Can you try restarting your computer to see if it helps?
Sometimes a pending Windows/OSX update can affect out login ability.
If that isn't it, can you send us the autodesk.streamer.webdeploy.log file? Can be found:
Regards.
Are you still seeing an error when logging in?
The log file showed a benign error when copying files but nothing that would indicate any login issues.
If you are still seeing errors can I ask that you send us the AppLogFile?
These are found in:
c:\users\{username}\appdata\local\autodesk\autodesk fusion 360\{alphanumericfoldername}\logs
You'll see log files that start wth "AppLogFile" and include the date/time of the sessions.
Thanks for the file. From the errors (Errno 11001) it appears there's an unstable network connection.
Can you try the steps outlined here:
