Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
login first start fusion360
6 REPLIES 6
ptrfpp
569 Views, 6 Replies
ptrfpp
After i installed fusion 360 it does not start. it says there is a problem why it was logging in.
6 REPLIES 6
baribak
in reply to: ptrfpp
baribak
Sorry to hear of the trouble. Can you try restarting your computer to see if it helps?
Sometimes a pending Windows/OSX update can affect out login ability.
If that isn't it, can you send us the autodesk.streamer.webdeploy.log file? Can be found:
  • OSX - /users/{username}/library/logs
  • Windows - c:\users\{username}\appdata\local\autodesk
Regards.
Kevin Baribault
Fusion 360 Quality Assurance
Regards.
Kevin Baribault
ptrfpp
in reply to: baribak
ptrfpp
As requested, here the autodesk.streamer.webdeploy.log file
baribak
in reply to: ptrfpp
baribak
Are you still seeing an error when logging in?
The log file showed a benign error when copying files but nothing that would indicate any login issues.
If you are still seeing errors can I ask that you send us the AppLogFile?
These are found in:
c:\users\{username}\appdata\local\autodesk\autodesk fusion 360\{alphanumericfoldername}\logs
You'll see log files that start wth "AppLogFile" and include the date/time of the sessions.
Kevin Baribault
These are found in:
Kevin Baribault
ptrfpp
ptrfpp
Now Is working 🙂 i do not know what you did but now I can open it. Thanks
HERE IS THE FILE YOU ASKED
baribak
baribak
Thanks for the file. From the errors (Errno 11001) it appears there's an unstable network connection.
Can you try the steps outlined here:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Kevin Baribault
Kevin Baribault
