Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Local rerender option unavailable
2 REPLIES 2
thomasjsimon
564 Views, 2 Replies
So after I run a local render, and open the image in the render gallery dialogue window, if I then hit the blue "rerender" button the subsequent render settings dialogue only gives me the option to rerender using cloud credits. I can only imagine this is a bug?
Thanks!
2 REPLIES 2
ryan.bales
in reply to: thomasjsimon
What you are seeing is that some types of render are in fact cloud only - turn-table renders, motion study renders and re-renders. This is mainly because you are reprocessing an image saved in your gallery - which is not a local gallery.
One thing to workaround this is to use named views to create render preset views, then you can use the views to rerender locally.
Ryan Bales
Fusion 360 Product Support
thomasjsimon
in reply to: ryan.bales
Ah, that makes sense. Thank you for the explanation! And yes, I have started to use Named Views just as you suggested.
