In this lesson the Reference Image to import is missing (can't be downloaded).
Solved by jhackney1972. Go to Solution.
The "Saw_Image.png" file is located under lesson 7 in the lesson menu. I have attached it to this post as well.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Well, lesson 7 is only an introduction / information. It never asks you to do anything.
Lesson 8 is asking you to import the image. To be consistent with previous lessons, all files that is being asked to be uploaded / imported should be available at each chapter using them. The "missing" file is again available in lesson 12
So I think the file should be moved from lesson 7 to lesson 8.
You are preaching to the choir! I agree with you, but I thought all you wanted was the file so you could move on.
John Hackney
Retired
