Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Lesson 8 missing files
3 REPLIES 3
max.kielland
385 Views, 3 Replies
In this lesson the Reference Image to import is missing (can't be downloaded).
Tags (1)
3 REPLIES 3
jhackney1972
in reply to: max.kielland
The "Saw_Image.png" file is located under lesson 7 in the lesson menu.  I have attached it to this post as well.
John Hackney, Retired
max.kielland
in reply to: jhackney1972
Well, lesson 7 is only an introduction / information. It never asks you to do anything.
Lesson 8 is asking you to import the image. To be consistent with previous lessons, all files that is being asked to be uploaded / imported should be available at each chapter using them. The "missing" file is again available in lesson 12
So I think the file should be moved from lesson 7 to lesson 8.
jhackney1972
You are preaching to the choir!  I agree with you, but I thought all you wanted was the file so you could move on.
