Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Large assembly crashes when updating references (all versions)
5 REPLIES 5
HenryDara
889 Views, 5 Replies
My design will open, but Fusion hard crashes when I try to update the external references. All versions crash hard, and I have send many crash reports to Autodesk this morning. Hoping the community can help.
Problem happened when Fusion was running real slow, so I restarted my PC, and now all versions crash.
I also noticed that I dont get the get latest feature except in the top bar (not at component level)
https://a360.co/2DP1k3d
Thanks...Henry
5 REPLIES 5
HenryDara
in reply to: HenryDara
After trying a bunch of things to recover the file, here is what I found (not much)
"Get all latest" would crash 360 hard, and there was no option to just update the offending component reference in the main design, but I could when I opened the sub assemblies that contained the old components.
I thought there was a "get latest" when I right click on the out of date component, but in this case that option didnt exist, so I had to open its design separately and get latest there.  That is fine by me, but "Get ALL latest" crashed fusion hard every time. When I updated everything myself bit by bit, I was able to get the design recovered, but had to delete some components in the process. Now I have to try to get those put back in to the main file again.
Unclear yet why the components all of a sudden became "outdated" for no reason (they were up to date at the time that I saved the project before restarting my PC) but I suspect Fusion got tripped up in its file handling somehow at the time that I shut down the PC.
In the end no answers, but at least things are kinda fixed...for now.
TrippyLighting
I downloaded your assembly and it looks spiffy clean!
I was able to open many of the sub-assemblies without a problem.
However when I opened the top level assembly Fusion 360 crashed, without be trying to update anything. Just opening the assembly!
@ryan.bales it would be good to check this out!
ryan.bales
in reply to: TrippyLighting
I'm getting the same thing. Crashes on open. I'm not sure how much i can provide to this one @HenryDara, does it crash for you on open?
Ryan Bales
Fusion 360 Product Support
HenryDara
in reply to: ryan.bales
Im not sure which version your looking at now, I was able to open it, but it crashed when I tried to Get All Latest.
I am now working on v141  ( https://a360.co/2DP1k3d ) having moved on, and it opens fine now that ive manually updated the references. It seems we are all getting different behaviors from the same file.
Thanks...Henry
HenryDara
After moving on, I had another kind of odd thing happen with this file...
Where the MCP needs updating, I do a Get Latest for just that component, and a bunch of joints go wacky that dont seem like they should be affected at all by the MCP as far as I can figure.
Anyhew, I was able to delete the MCP without getting any errors, then re-inserting it back into the main design, but then it would not let me joint it in the main design. Getting compute failed error (like I usually get when ive jointed something wrong somewhere)
Narrowed the offending feature in the MCP to a Body to Comp 1 (the MCP), which happens late in the timeline after all the modeling stuff, but before attaching and joining all the hardware to the new components (from bodies)
Is this where I went wrong, breaking rule #1? If so, is there any way to fix it besides remodeling the parts following rule #1 better? These days I always create the component first, but this was created prior to me doing that by default.
Thanks...HD
